Nytecholdie
Hi all
Heres a pic of the two different pots used in the Obelisks
The picture on the left is of the earlier Nytech CA102 and very early Ion Obelisk 1s. I dont know who made the original 50k pot and it has an unusual pin out. There doesnt seem to be anything around today with a similar layout.
The picture on the right is from an Ion Obelisk 1 and most of the Ion amps used the Alps "blue" pot which is still available.
It is possible to bodge - sorry! modify an Alps pot into the earlier amps but you need to drill holes for the pins in the alps pot and butcher the pcb underneath to hard wire the connections. Theres no decent mechanical support unless you make up a "L" shaped bracket (like on the later Obelisks - see pic above) Its actually easier to make up the bracket, turn the pot upside down (pins pointing up) and run wires to the original points on the PCB. Doesnt look as neat but is a lot easier to do!
Both amps used a 50k pot. You can also use the Alps "blue" 20K as the 50k version seems harder to come across these days.
Hope this helps
Hope this helps
