I agree with Mudlark, the casework did let the amps down. From an electronic design point of view they were good though. They chose to use their own transistor regulators and capacitor multipliers rather than go down the Naim road of using IC regulators. This decision gave them the edge in terms of sound quality and improvement potential IMHO but at the expense of a more complex circuit and build. The wiring inside the cases to the multiple boards in a tight space was a tricky job in the factory. The build costs must have been higher as a result and dug into their margins. Check out this picture of the CP112:
There were a multitude of other clever design tricks in the Nytechs and Ions. On some of the power amps they had two feedback networks, one either side of the output capacitor. That made the output cap more linear in the circuit and is arguably a better design choice than having a direct coupled split rail amp circuit like the Naim one. I have modified some Ion Obelisks by adding this second feedback loop around the output cap to good effect. The evidence is here:
There are other real improvements that can be made to the already well designed Nytech/Ion power/pre amp circuits that do nothing but develop its qualities further. That's why I like these amps so much. The only problem is fittting the improvements into the case - which is why Ion themselves came up with the piggybacked power supply option. Some guys have admired the design so much they have done a total rebuild:
I do have some gripes from a circuit design point of view though. The early Nytech/Ion Obelisks had poor thermal management in their power amp. This was sorted in later versions but I have mended three that had gone into thermal runaway and blown fuses and output trannies. They were skimping on heatsinks and it caught them out a bit. I've got the picies to prove it. I get the feeling that they briefly lost the understanding of their own design, possibly when some key individual left. There is evidence that they tried to copy and scale down earlier circuits and misunderstood how they worked for a while when the Obeisk came out. They sorted the glaring errors but never fully replicated all the clever bits from the Nytech era.
What I hope to do one day is design an amp that incorporates all the best bits of the Nytech and Ion amps, and have it all on a single circuit board in a decent case. That would be a winner.
John
