Meridian 104 Tuner Q?
Discussion in 'd.i.y.' started by neiljadman, Sep 17, 2009.
  1. neiljadman
    neiljadman Senior Member
    Noting much really - it works great - just that the bulb illuminating the meter is out - anyone know what it is?
  2. neiljadman
    OK, fixed - a standard white LED with a 1N4148 diode across it works wonders....
  3. martin clark
    martin clark pinko bodger
    Care to show any more of the 104? It's supposed to be very good indeed, and finding a nice one is on my 'want to try' list...
  4. neiljadman
    I'll post some pics... and yes they really are very good indeed...open, accurate and good bass. So good I have two...and I listen to it more the the NAT01/NAPST if that says anything.
    Like everything 100 series Meridian they were strangled by the "power daisy chain" and really benefit from being connected directly to power.
    This one started life as UK spec unit and was converted to US when I came over here 20 years ago. I just recapped it a few months ago and at the time didn't bother to replace the lamp as I couldn't find one at a high enough voltage. It's a T5 I think - anyway a 5mm LED slots right in, and runs of 32vAC directly after the transformer - hence the diode across the LED to block the reverse voltage.
    But having 5 tuners a I have decided to part with this one - hence the desire to re-illuminate the meter. And the LED works remarkably well and should be more durable than another incandescent bulb.
    I'll post some picx as soon as they have uploaded to photobucket.
  5. neiljadman
    OK, here's a few picx...
  6. martin clark
    Thanks Neil...
  7. Mr Tibbs
    Mr Tibbs Infinitely Baffled Member
    Nice.
    I hankered after one of those after I bought the 101 preamp (many, many moons ago)
    Got any internal pic's?
    Mr Tibbs
  8. Yank
    Yank Bulbous Also Tapered
    I'll second the request, especially since this is the DIY forum.
  9. neiljadman
    Album now updated with a few internal picx...
  10. Yank
    What's that brown thing under the boards that looks like a paper bag?
  11. neiljadman
    Paper bag probably not, but treated paper of some sort it is. It's a feature of all 100 series units and I always assumed it's to prevent any accidental short from the underside of the board to the case things - are all very close together in these diminutive cases.
  12. Yank
    Quaint. Adds a nice "cottage industry" touch.
  13. Mr Tibbs
    Thanks Neil. I like it even more now!
    A few linked for easy viewing here;
    Mr Tibbs
