MDAC first listen (part V)
Discussion in 'audio' started by Oktane, Mar 11, 2012.
Thread Status:
  1. JohnW
    JohnW Trade: Lakewest
    I was looking at one of the 20W processors....
    John
  2. JohnW
    Random miss lock - Due to a design bug in the ESS DAC IC, once in a blue moon its prone to miss lock...
    I've personally not experienced it for a while...
    Are you still on the original software - or one of our Pre-release Beta's?
  3. noricom
    noricom New Member
    Thanks, you got post :cool:
  4. ddenyer
    ddenyer pfm Member
    Hi John, I'm on the original software.
    Derek
  5. John_73
    John_73 pfm Member
    Mines crackled 3 times this evening now - all using USB. Any filter setting. 16-bit material. Left channel only. Cycling inputs 'cures' it for a random period of time...
    Hopefully this can be solved with another firmware release?
    - John
  6. JohnW
    Hi John,
    Its no the Buffer level is it? Enable the buffer display and just confirm that it remains around 50% during "crackling",
    John
  7. sam_cat
    sam_cat ʇɐɔ_ɯɐs
    Why not go for a fusion/higher spec atom? I use a fusion based pc for playing blu-rays, dvds, streaming films off my network (dvd images), playing music off spotify, Iplayer and locally hosted flacs.. Has no problems what so ever doing any and all of the above.. Have also used it for ripping dvds/cds and does that faster than my laptop..
    And there are native distros compiled for OpenELEC, the open source XBMC operating system.. Very very slick to use!
    Just my rambing thoughts on this as I have been on this very same journey recently.
    Sam
  8. gh0st
    gh0st pfm Member
    +1 for OpenELEC, I have it running on an old (by pc standards) acer revo nettop with an atom 330 and it pulls like a train, hdtv no problem...
  9. sam_cat
    sam_cat ʇɐɔ_ɯɐs
    The only test I havent done with openelec and my mdac is the bitperfect test.. Would be interesting to see if it passes.
  10. fusion5
    John, is there a reason for picking the H61 Chipset over H67 and Z68?
    Since the release of the MITX is not imminent maybe you should consider using one of the upcoming 22nm Ivy Bridge CPUs and a mainboard featuring a Series 7 Panther Point Chipset.
    Nevertheless I like your choice to go with an Intel mainboard. Many of their mainboards have a internal CIR (Consumer Infrared Receiver) header. You could integrate an IR receiver into the MITX. Intel provides a Windows driver with the mainboards. If I remember correctly, this solution is fully MCE Remote compatible and can be used with a lot of universal remotes (like a Logitech Harmony).
    There are fully assembled IR receiver kits like this:
    http://shop.inteset.com/Products/5-intel-cir-receiver.aspx
    And I remember some guy on the AVS Forum describing how to build your own:
    -> http://www.avsforum.com/avs-vb/archive/index.php/t-1050640-p-7.html
    Besides the possibility of nearly invisible integration this solution has a big advantage over external usb ir receiver: It can power on your pc!
    Don't know if this works with Linux :confused:
    Michael
  11. jagdesign
    jagdesign pfm Member
    Any news on the software?!?
  12. PhilCTTE
    PhilCTTE Senior mumbler
    Thanks for the reply. Just getting itchy feet on getting a quality hifi streaming device in place.
    Living with laptop at the moment, but its a general use one and it has no place along side the rest of AV hifi. Unless I do late night listening I'm finding that I just grab the odd 1/2 hour here and there. So need to find simple switch on and play device which is high SQ.
    Looks like we'll be lucky to see the MITX this year maybe ... ?
    I've tried Sonos/SBT but not cutting it , for me.:confused:
    Thinking about it, might get an IPAD to stream from in the iterim
    Can't believe how good spotify sounds via MDAC btw ...thanks again for this amazing product. Currently listening to new spotify app callled digster. Kanye West playlist :D
  13. gh0st
    gh0st pfm Member
    What's not to like about bitperfect output from an SBT? :confused:
  14. JemHayward
    JemHayward pfm Member
    I get occasional white noise type of effect through left channel. I power cycle the MDAC and it's ok again. On original software. Happy to try new update, in fact really looking forward to it, but, as this has happened maybe three times in six months, not sure I'd be adding much to the knowledge base!
  15. PhilCTTE
    bitperfect plus noise;)
    To be fair never got round to trying USB mod. Wasn't avail when I sold.
    On its own no server the SBT was slow and failed regularly on hires.
    My nas is a basic WD affair , processor not upto job to run LMS.
    Straight comparison on hires material betweem SBT and Laptop was close, but there was a difference in SQ and the laptop won (MDAC usb did the job). My thought was to invest money on dedicated server . Can't get my head around the need for SBT plus PC, when bespoke PC server will beat the SBT on sound quality..
  16. Cereal Killer
    Cereal Killer fourhundredandthirtytwo
  17. PhilCTTE
    With you on that..
    But with the MITX build John will also include 192 to optical conversion from USB to connect to the MDAC. If I spend £400 - £500 on a build now it would probably be redundant when the MITX is released. So IPAD for now
Thread Status:
