JohnW
pfm member
iirc it's not about the number of bits - think you have to go a lot lower for that to be a factor. it's more about the audio signal being reduced whilst the digital noise level stays constant - at least thats how i remember it.
Exactly my concern.
I'm not so concerned about the the digital attenuators in regards to "Loosing Bits" but rather the level of RF "crud". Digital products produce certain levels of RF crud which can upset the input stages of most amplifiers.
With a Analogue volume control, both RF and audio signal are attenuated - but with a Digital attenuation the RF is always at "full tilt" while the analog signal is attenuated... so at lower listening levels the RF level can start to be more "pronounced" compared to the analogue signal.
Using external attenuators to "pad down" the output level which reduces both RF and Analogue signals - which is desirable.
In fact thinking about it while I'm writing this post, and I'm going to add an internal -20dB attenuation option to the BDAC - thank you for making me think...!
