Hi tim,
File sent - good luck (did the SBT arrive yet?)
Hi John, SBT turned up yesterday - much obliged.
I've just loaded up Adrian's modified kernel. Couldn't believe how far he has bought this patch since John Swenson's (very much appreciated) early work, and how easy it is to install/remove. He really does deserve a huge credit for getting it to this stage. I also had a quick go with one of his later Kernel versions and I was able to also get 192/24 material from the SBT SPDIF!
Just orderered a USB hub and will have a try later with the USB isolator to see if I can hear any difference.
