Probably me being a bit slow, but I don't understand what you mean by "the internal server". Are you saying the SBT can act as a music server on the network, or are you referring to its ability to send data out of its digital outputs ?
What problems are you getting installing the software? In my exerience, you just run the installer and tell it to scan your music library. The SBT then detects the server on the network when you boot it up and is able to access that same library. Not much to it really.
I can see that running it on a NAS might be a bit hit and miss, but I'd have thought most PCs should be up to the job. Until very recently I was running it here on an old low-spec Athlon based machine in my loft. I did have a problem at first where the music would intermittently hang, but I solved this by disabling all the unwanted plugins which I'm guessing were bumping up the resource requirements. It was fine after that. Might be worth a try?
Yes. This should not be a problem. How are you feeding the MDAC?has anyone got the bitperfect test passed on win7 and foobar?...I failed with both WASAPI and ASIO4ALL, now I resetted and I start again form the beginning, starting with WASAPI then ASIO4ALL
Valve head, the ESS chip runs an asynchronous up sampler as part of the dejittering, so everything is up sampled the dac chips native internal rate. I forget what it is, but it's high...
Thanks SQ225917 (hope I got that right! ). I'd always been lead to believe that upsampling was 'bad' if one was intent upon protecting the purity/integrity of the original file, but I guess in this case it doesn't appear to have impacted upon the sound quality of the final unit judging by the reviews/opinions I've read so far. Nearly got the money together for one now... and it looks like they're sold out everywhere! Typical
- John
upsampling to a much higher frequency works well. synchronous upsampling (to an integer multiple - eg. 4x) works very well (based, if nothing else, on my experiments with upsampling)I'd always been lead to believe that upsampling was 'bad' if one was intent upon protecting the purity/integrity of the original file, but I guess in this case it doesn't appear to have impacted upon the sound quality of the final unit judging by the reviews/opinions I've read so far.
The ASIO setup has now changed a bit from that described in the MDAC manual. Are you using the latest Foobar (1.1.10)?My system has started to "stutter". The MDAC is running on USB from a PC with Foobar and Asio4all installed.
Doh! Reset the Asio Buffer size to 2048 samples and now all seems fine.
Anyone else had the issue of recently downloading Foobar and the Asio out component, or is it just me?
Cheers
Ian
MMMMMahler no more.
Cheers
Ian
MMMMMahler no more.
M-DAC displays Test Failed after few seconds.
I succedeed in achieve bitperfect test using wasapi but only for the 16bit44.1KHz file.
Now I receive test failed again also on this file, without having touch anything, very strange
