laverda
I'm after some advice, I have this Sneaky DS which had died, It's not mine I'm having a looking for a friend. On inspection there is no output from the SMPS, I do have 153vdc at the main caps though so have ruled out the inline T1.6a inline fuse. The daughter board has a 12v pin which measures 153v?? Which I don't think is right. There are no signs of heat stress anywhere or blown caps...no relays click but on power off (after 30 seconds or so) I do hear a click click click which fades away but its not any of the relays.
I have been told Linn no longer service / repair these or if they did it was prohibitively expensive.
Is this SMPS repairable or is it worth it?
TIA
TIA
