Musicraft is pleased to announce that last Friday we received the UK's first stock of JL Audio's new
Dominion d108 (500w) and
Dominion d110 (750w) subwoofers.
SUB BASS BY JL AUDIO. ADDING A NEW DIMENSION OF DEPTH WITH SPEED AND POWER TO ENHANCE YOUR AUDIO SYSTEM
JL Audio Dominion d108 (500w) sub
JL Audio Dominion d108 sub with grille on
JL Audio Dominion d108 sub rear panel
JL Audio Dominion d108 sub control panel
JL Audio Dominion d110 (750w) sub
JL Audio Dominion d110 sub with grille on
JL Audio Dominion d110 sub rear panel
JL Audio Dominion d110 sub control panel
JL Audio badge on Dominion d108 and Dominion d110 grilles
JL Audio JLINK™ TRX Wireless, High-Fidelity Audio Transmitter & Receiver Kit
JL Audio JLINK™ RX Wireless, High-Fidelity Audio Add-on Receiver
Dominion™ powered subwoofers benefit from JL Audio’s expertise in driver and amplifier design to arrive at a unique solution for applications requiring a compact, more affordable subwoofer.
Unlike any other product in its price class,
Dominion™ powered subwoofers combine a purpose engineered, DMA optimized, long excursion driver with an advanced Class D amplifier equipped with a tightly regulated switching power supply.
Dominion™ powered subwoofers can be used in a variety of compact applications, including full home theater systems, media room systems, dedicated two-channel music systems, desktop audio workstations and small recording studios.
Born from JL Audio’s vast collection of advanced technologies,
Dominion™ powered subwoofers combine a state-of-the-art subwoofer driver and an advanced Class D amplifier to deliver unmatched performance and value for a wide variety of compact applications.
Purpose-built to reproduce powerful low-frequency events with stunning impact and precision, the
Dominion™ driver employs JL Audio’s exclusive DMA (Dynamic Motor Analysis) technology to produce higher output levels with reduced distortion, as well as improved dynamic tracking and resolution. As a result,
Dominion™ subwoofers are capable of peak-to-peak excursions well in excess of 2.5-inches (63 mm - d108), and 2.7 inches (68 mm – d110), without distress or audible distortion.
Dominion™ amplifiers utilize an advanced Class D design in order to extract the most from the long-excursion driver platform. This design features a tightly regulated switching power supply, allowing the amplifier to generate prodigious amounts of unclipped output voltages. These technologies ensure that the
Dominion™ powered subwoofers remain in their comfort zone, which is well beyond the point where most small subwoofers run out of power or driver capability.
With a host of signal processing features included,
Dominion™ powered subwoofers can be integrated into most systems with ease. Low-pass signals are precisely guided, thanks to the onboard crossover’s 24 dB/octave Linkwitz-Riley alignment. Phase and polarity controls are onboard to aid in achieving the optimal acoustic transition between the subwoofer(s) and main speakers. Flexible input options are on-hand to accept either line-level or speaker-level signals. Connect a
JLINK™ TRX system (sold separately) to the onboard Wireless Link port and enjoy the freedom to position your
Dominion™ almost anywhere, up to 100 feet (30 meters) away from your source unit.
To contain the immense pressures created by the
Dominion™ driver, each beautiful cabinet is carefully engineered and constructed using solid, CNC-cut, MDF material with extensive internal bracing and advanced assembly techniques. All
Dominion™ powered subwoofers are built with pride and precision in JL Audio’s U.S. factory to deliver years of listening enjoyment.
Finishes: Gloss Black or Black Ash
Grille Finish: Black Fabric
Enclosure Construction: MDF
https://www.facebook.com/MusicraftUK *****
Rick @ Musicraft
