eb5agv
Member
Hello Tom,
Thanks a lot for answering my query and doing it so fast !
This TLB 3 is an all black case.
Well, good thing is that I can pick it up locally, so will save on shipping costs... I am a newcomer to HI-FI so I guess it will be a good addition to my setup which currently is composed of:
I know it is a low budget setup, but it sounds fine so far
Do you think the Little Bit 3 will improve the CD sound?
Thanks and best regards,
JOSE
At £85 a mint condition TLB3 is a bargain.
Should you not like it, you should not make a loss on reselling it.
Tom
PS Whatever the colour of the casework, the PCB is the same.
- Philips CDC-775 CD player (with S/PDIF output: I would use it for the Little Bit)
- Kenwood K-6040 tuner
- Yamaha C-45 preamp
- Yamaha MX-50 power amp
- AR Labs Mini Reference
JOSE
