I recently acquired an old Arcam Alpha amp (MK1 I believe) for my daughter. It was supposed to be working but there was only sound from one channel. I have established that the problem is with one of the holders for the 20mm 2A speaker fuses, accessed externally from the back panel of the unit. The fuse holder should look like this:
[/IMG]
The second fuse holder doesn't have the two metal clips that are necessary to lock in the fuse and presumably provide a contact.
I have emailed Arcam and had no reply, been to Maplin and looked online, but so far cannot identify a source for one of these. I guess it will be necessary to buy a complete fuse holder i.e. with the barrel into which the fuse is locked, but where I can see possibilities online there are not images showing the two parts disconnected (and many of the sellers anyhow seem to be wholesalers).
I would be very grateful for any advice on a source for this small but essential part.
Clive
Clive
