Hi,
After converting the phonostage into a line stage using this guide, the left channel (they are of course the other way round in Naim amps) works fine but the right channel hums and hisses, maybe the same as when the amp is idle but much louder.
When music is playing, you can hear only treble in the right speaker, the level of which is not affected by the volume control but is affected in the usual way by the balance and the input selector.
All of the inputs now behave like this, the phonos and the DINs.
When you put your hand near the capacitor (circled in yellow at the bottom right of my pic), the amp hums louder and, if you touch it, it hums very loud and you can hear a radio station through the right speaker! I don't have a tuner BTW.
NAIT 2 inside
I think that one of the components must have blown in the preamp, I can't see any bad connections.
Any help would be much appreciated.
Thanks,
Mathew
NAIT 2 inside
Thanks,
Mathew
