90125
A few years back I started a HackerNap project.
Family, work and the other usual stuff got in the way and it never got finished.
It would have / will be ..
Two Mono Blocks each with
Canterbury Winding Transformer .. 35-0-35 @9A rms & 42-0-42 @0.7V
Hacker Nap board (passives fitted, Silicon ready to fit).
Two Nacker Cap Boards (Silicon ready to fit)
1x Hacker Cap fitted with 6x Kendal 6800uF KO5
1x Hacker Cap fitted with 6x Another Lower Spec Electrolytic (need to look it up)
Avondale Soft Start
Velleman K4700 Loud speaker Protection.
An two Aluminium Cases (45x31x10cm) from ... the recommended Italian Supplier
To finish it needs the Silicon Soldering and the "top level" wiring.
As this has been on hold for way too long and we no longer have the space .. it needs to be sold.
Before I put it in the classified .. would you split it? What do you think is a fair price?
David
Avondale Soft Start
David
