good, SMALL solid state amplifiers? on a budget...and not Class D
Discussion in 'audio' started by jamesd, Oct 15, 2017.
  1. jamesd
    jamesd pfm Member
    thanks for all the suggestions
    monoblocks definitely don't work as I'm trying to reduce boxes and cables if i can.
    I suppose if I'm wrong about Class D amplification, it would be worth my while to try the new Mytek amp that matches my Brooklyn.
    I'd really love the Benchmark amp but it's out of budget.
    I'm looking into all of these other options. Thanks for all the advice.
  2. eastone
    eastone pfm Member
    One last suggestion: Quad 303.
    Plenty info on it round here, I know Tony is a fan.
    In my experience, and going by your previous choice of integrated, the Snells appreciate a bit of valve character, which the 303 is reputed to do very well for a solid state device.
  3. Alan Brown
    Alan Brown Registered LUser
  4. G T Audio
    G T Audio Trade: Distributor and Manufacturer
    Understood that's why we designed the stereo version. 50w + 50W in a mono case.
    A bit left field I know but how about a Marantz PM4 integrated? 15watt class A, or 60watts in AB at the push of a switch. Also MM & MC phono inputs. Beautifully made and sounds really nice, especially on the class A setting.
  5. Julf
    Julf Evil brother of Mark V Shaney
    It does. Are you running standard nCores or ones with a Nord buffer? We need to know the voltage gain of the amp.
    There is also the problem that we can only control the voltage, not the power - the relationship between voltage and power depends on the actual impedance of the speaker, and that varies with frequency. On the other hand the 100W power handling is a very approximate value too.
    Here is a slightly simplistic analysis:
    Assuming a nominal 4 ohm, it takes 20 V (RMS) at the amp output to produce 100W. The standard hypex nc400 has a voltage gain of 26 dB, corresponding to a ratio of 20, so you want to limit the input voltage to 1 V. The Dragonfly Black has an output voltage of 1.2 V, which is only 1.5 dB above 1 V, so as long as you stay 1.5 dB off full volume, you should be OK (all assuming standard hypoex voltage gain).
  6. Yomanze
    Yomanze pfm Member
    Good, small, solid state, on a budget, no class D: take a look at the many "Gainclone" amplifiers available.
  7. Whaleblue
    Whaleblue Box-swapper extraordinaire
    Thanks Julf,
    Mine are these, NC500 based, with Sonic Imagery 994 Op Amps:
    https://www.nordacoustics.co.uk/product-page/nord-one-se-up-nc500mb-mono-block-black-single
    The speakers are Yamaha NS-1000Ms, nominally 8ohm.
  8. Julf
    Problem is that Colin and Mike don't like to talk technical stuff - I don't know if their buffer and op-amp adds gain or not.
    9 ohm would require 28 V at the output to produce 100W, so 1.4 V at the input if the gain is the hypex-standard 26 dB / 20x, but nominal impedance is just that - nominal.
  9. Whaleblue
    Thanks again. So, assuming no gain in the buffer, and only considering nominal impedance, the Dragonfly at full tilt through the ncores would produce less than 100w.
    I’ll just Keep it to max -10db :)
  10. jamesd
    jamesd pfm Member
    Anyone have experience with the Bel Canto 5ci? It is Class D and only has a MM section, but a once box solution is very appealing
  11. Arkless Electronics
    Arkless Electronics Trade: Arkless
    +1 I repaired and recapped one of these recently and can confirm that they sound very nice when set to class A.
  12. jamesd
    jamesd pfm Member
    The Marantz looks cool but about twice the width the width that I need
  13. ryder
    ryder pfm Member
    The appeal of a small integretad cannot be disregarded. Small, neat and tidy. The usual suspects would be as follows.
    Rega Brio
    Exposure XM5
    Naim Atom
    The Atom is costly but it's an all-in-one.
  14. Julf
    Yes.
    That should do it. :)
  15. Cellofan
    Cellofan pfm Member
    Rega Brio, still for me the amp in that pricerange.
  16. Hempknight
    Hempknight pfm Member
  17. stevec67
    stevec67 pfm Member
    I have an A&E DCA-100, shoebox format, sounds lovely. Rare as a happy Remain voter, thouh nicer to have around after the evening news.
  18. jamesd
    jamesd pfm Member
    really dig the looks of that thing. looks like it's a "normal" height, though.
  19. jtrade
    jtrade pfm Member
    Oh, dear, I want one....
  20. Rosewind
    Rosewind Lost in Translation
    There is one for sale in Germany at 120€. I am tempted too, but I can ill afford a unit that needs repair.
