Elsdon Wonfor Audio LS-25 speaker cables
Discussion in 'audio' started by Cereal Killer, Jun 28, 2017.
  1. Cereal Killer
    Cereal Killer fourhundredandthirtytwo
    I agree! the differences are subtle but none-the-less advantageous.
  2. YNWOAN
    YNWOAN 100% Analogue
    It's not that I don't believe in cable differences, I do - but I've never heard any evidence to support the belief that cables burn in. None of the many ones I have tried have altered at all with the passing of time.
  3. Cereal Killer
    Yes I'm with you on that one and I think no one can claim a measured difference either. But from my experiences with 3 new sets I had here, being VOVOX, HiDiamond & EWA all changed over the first week.
    VOVOX (being a pro cable manufacturer too) state their cables change in the first 20 hours and will subtly change thereafter for a longer period.
  4. Cereal Killer
    http://www.vovox.ch/en/home-audio-hifi/faq/ extracted below:
    In general: yes. However, the necessary run-in time is quite variable for the different cable types.
    Upon our point of view, the reason for this run-in effect is still unclear and not understood. Nevertheless, after some time of use we detect clear changes in sound quality, such as:
    •better spatial resolution, especially for instruments and voices in the center
    •perfect sound balance
    •more naturalness
    •more even sound pattern
    break-in times:
    •vocalis: long break-in time (min. 20 hours), great effect
    •textura / textura fortis: these sound conductors are pretreated in a specific process before they leave our factory, but allow 1 hour of „warming up“ for perfect sound. Moreover, the result further improves during the first 100 - 200 hours of use.
  5. YNWOAN
    I'm really not convinced.
  6. Yomanze
    Yomanze pfm Member
    Me neither, but I have slowly adjusted to the new balance over time...
  7. Dark Energy
    Dark Energy pfm Member
    Re cable burn in, it's actually the dielectric that "burns in" or reaches optimum charge or whatever it is that's going on. PTFE (Teflon) demonstrates this phenomena most readily, to the point that if you leave a cable unused you need to burn it in again, same with Teflon capacitors. Same for other dielectrics just more noticeable with Teflon. If you use cables with PVC dielectrics all bets are off! Have you wondered why there are no PVC capacitors?
    While the vast majority of the cables out there are much of a muchness, there are some that offer huge performance upgrades, problem is finding them! In the 90s I remember doing some comparisons with a bunch of the best interconnects of the era, not much to choose between most of them (and I think this explains why people claim not to hear much in the way of meaningful differences) However there was one design that sounded so good that it sounded like an expensive amplifier upgrade, really jaw dropping and impossible to miss. There was another that was new to the market, with radical technology while receiving really very good reviews, but I, and everyone else who heard the comparison between these two cables hated it!
    What I found most interesting was that these comparisons were carried out with Audio Research, Krell and Mark Levinson Amplifiers. When this remarkable cable was used with a Naim NAC52 NAP135s Amplifiers the performance advantage just evaporated. I'll let you ponder why that might be. ;)
  8. Cereal Killer
    That could explain it then, apparently every strand of whatever is inside the LS-25 has a its own coating of 'something' which has to be removed before soldering (Mark mentioned this in discussion) This is why its only available terminated, it needs burning off carefully with controlled heat and is time consuming.
  9. YNWOAN
    The idea that the dialectic alters is a novel concept but there is absolutely no evidence to support it outside of creative hypothesis.
  10. Cereal Killer
    Same goes for skin effect IIRC.
  11. thebiglebowski
    thebiglebowski pfm Member
    Skin effect is well understood but not an issue as it does not occur at the low freqs used in hifi.
    IMHO burn in does not exist, what does happen is that over a period of time your hearing/brain is adjusting to this new presentation.
  12. Cereal Killer
    I disagree.
    Have look at these links Colin posted on the TQB thread a while back when we were discussing his design/s http://www.pinkfishmedia.net/forum/showpost.php?p=3108936&postcount=326
  13. Cereal Killer
    Has anyone else on PFM got these in there system/s yet?
  14. YNWOAN
    Yup, none of those links appear to contradict the idea that skin effect is not relevant at audio frequencies.
  15. Cereal Killer
    From the previous TQB thread:
  16. FireMoon
    FireMoon pfm Member
    Awaiting to hear back from them after emailing them about what I require.
  17. Cereal Killer
    Cool!! maybe quicker to call Mark though! :)
  18. FireMoon
    FireMoon pfm Member
    Couldn't find a contact number for him. PM me if you have one please?
  19. Cereal Killer
  20. FireMoon
    FireMoon pfm Member
    Ahh right got it... cheers
