Hi all,
I built a dual Hi-cap from a full width case Hi-cap plus spare Talema transformer (all employee sourced), and a pair of AWSR boards that I had fitted to another DIY power supply (link below) and in the current system I have a 'spare' Hi-cap effectively. I have a question about connecting this to a NAC 82.
According to Naim manuals, a NAC 82 can be powered by one or two Hi-caps, one or two Flatcaps, or a Supercap. I was wondering what is the collective opinion about connecting my 82 up to both the Hi-caps in my single box dual Hi-cap, e.g. is it a huge improvement over a single Hi-Cap, and more importantly is there any reason I shouldn't ??
My thinking is that with two separate Hi-Caps or Flatcaps, it is essentially the same as my single box (note that the only shared components are the incoming supply cable and the on/off switch, the LED at the front is powered by just the one Hi-cap obviously).
Would really appreciate any general points of view and real experience with a dual Hi-capped 82 especially.
https://www.dropbox.com/s/q1pnmxivih0bpod/DIY HCAP.jpg?dl=0
Cheers
Cheers
