dadgad
Well the 303 is rated at 45w/channel, the same as my old Meridian 103D which works well and the same as the old Technics mentioned above. There could be an issue with high current at low impedance, I guess - depending how loud the OP likes the music?Not sure a 303 will drive Kans, should you now consider that route... might need a bit more oomph...
