Arkless Electronics
Trade: Amp design and repairs.
And your point is? You seem knowledgeable about electronics and I'm sure I would be wasting my time in explaining the advantages of the 3 op amp topology over the single one.
No you don't need more than one op amp or an extra transistor and I didn't say you did....but both are poor methods of doing it.
We'll have to agree to disagreeThere is a clear advantage - avoiding ground loops. And why would you need to add 3 op-amps? If you already have one op amp in the input circuit, it will have an inverting input too, so no added components are needed at all. If the input stage is discrete, you need one extra transistor - and it is only "in the signal path" in the same way as the single-ended one is.
It's not to do with the advantages of the 3 op-amp configuration,
It's to do with the fact that most(?) single ended input stages are inherently balanced as there's a corresponding -ve input within the circuit. So balanced can often/usually be achieved with no additional active components
You seemed to previously disagree with julf when he said "no additional components, or only 1 transistor"
I repeat that my argument has nothing to do with how few components is is possible to get away with and everything to do with doing the job properly. I would not use the circuits presented by Julf as there are much better ways of doing it.... and no I'm not going to go into detail as lifes too short...
Leaving aside the combative element of the exchange, is there any obvious problem with your 1 transistor approach vs the 3 transistor eg can you achieve similar CM noise rejection?"Balanced is bad because the circuitry is complicated. I know it doesn't have to be complicated, but I think it has to be complicated to be good. Thus balanced is bad because it is complicated."
Presuming you mean op amps and not transistors, the issue with the single op amp circuit is that it only performs well with an ideal low (and matched + to -) input impedance source.
There are several other possibilities with two and more op amps, such as the "Superbal" topology.
Again we will have to disagree. The diff inputs do see the impedance to ground.
I would NEVER under any circumstances use the single op amp version at any interface with the outside world...
I also prefer unbalanced to balanced as a generality. There is no need for balanced in domestic audio and in most cases it greatly complicates the circuitry, often needing literally double the circuitry. It's just a fad intended to sell more high end gear, like so much in hi fi....
What part of agree to disagree do you not understand?
You seem as confused over this as over balanced audio where you seem to think all balanced signals don't "see" a ground reference and not just floating transformer outputs and cartridges etc
I do not like balanced for domestic audio due to extra complication, longer signal path and the doubling of circuitry in many cases. It's an answer to a non existent problem in a domestic context where people don't usually have to quickly set up 50M runs of cable for a gig without having to worry about ground loops or if the cable is run next to mains cables etc.
What you or anyone else likes is up to you. Hence agree to disagree.
I would never use a single op amp diff input as they are shite. Yes they are the most commonly used commercially... because they are the cheapest.
If you like this compromised bit of circuitry then go ahead and use it. That's your business not mine.
I dropped a huge hint in an earlier post which seems to have gone over your head... remember when I mentioned floating balanced sources?
Most balanced sources are not floating and do see earth. This is where your beloved single op amp balanced input fails so badly. The + & - inputs have unequal input impedances to earth. These form voltage dividers with the source impedances and, as the inputs are not the same impedance to earth, the CMRR goes out the window unless the single op amp version is driven from near 0R source impedances, which cannot be guaranteed and is indeed often not the case.... and I rest my case. Strangely enough I won a bet over EXACTLY this same argument with my then boss in the R&D department I was working for at the time...
We shouldn't confuse improved CMRR with "perfect"/optimum CMRR.
Over whose head?
It would be nice if this could be approached as an exchange of information amongst equals, rather than what appears to be an all or nothing/can't be bothered to explain
Of course balanced CMMR is at its optimum when the source output impedence is properly balanced. That's an inherent part of what makes balanced, balanced - which many don't realise.
Referring to the Balance section on page 3 and the accompanying equations on page 4 of Bruno Putzeys document. You can see the effect of an imbalance in the output impedance on the CMRR. And obviously, The higher the input impedance the greater the CMRR despite the imbalance in output impedance; and of course an instrumentation amplifier circuit has a nominally "infinite" input impedance and therefore provides a "perfect" CMRR when fed an imperfect output impedance.
However, balancing the input of a stage will improve the CMRR over that of an unbalanced stage. How well it improves it is dependent on the ratio of (unbalanced) output impedance to (balanced) input impedance. So the lower the output impedance and higher the input impedance, the better it will be.
If we knew the output impedance of the preceding stage/device we could add a balancing output impedance into the output ground connection of that device (going into the interconnect) and bring it even further into balance.
In Putzeys case he then goes on to apply balanced connections internally throughout an amplifier, but the principles and maths apply externally.
Indeed. I really don't get the "if it isn't perfect it isn't any better" argument. A pretty good CMRR, even if not infinite, is still much better than no common mode rejection at all (and that is what unbalanced suffers from).
It seems Arkless is saying "there is no point in flying cars because they won't be able to do supersonic speeds".
Like I said, point proved.
I rest my case.
The first comment was aimed at Julf.... and yes of course you can deliberately "unbalance" the balanced input to give improved CMRR with a specific known input impedance. Not exactly ideal for a universal balanced input! The single op amp version is best kept for internal use in a piece of equipment where it can be driven from known low source impedances from a previous op amp stage.
The main argument was whether or not a single op amp balanced input was a good solution. I have proven that it is not.
I prefer unbalanced to balanced in general for the reasons we started with... ie unless the circuitry itself is completely balanced it means adding op amps to the signal path.
Most so called balanced units are internally unbalanced. They then add op amps to the output to make it balanced just before it goes to the XLR socket. Usually the signal then goes through more op amps at the other end to convert it back to unbalanced where it then continues through unbalanced circuitry.
Outside of a pro audio scenario, where cables of 50M long etc must be connected up very quickly, and without a thought for where they are routed and what they are connected to, balanced is a solution looking for a non existent problem. It's just one of the many fads in hi fi designed to sell more units...
