Howdy
Can you demo that in store? Perhaps against P6 with Exact?As an alternative, they suggested I swap it for the lower output version, the HANA EL, which is 0.5 mV and switching to a used Rega Fono MC they have.
Not a fan of the Mk1 Lingo (not heard the others) but not a deal breaker as it can be swapped out if you want.Like this one for only $2300- about the cost of a Planar 6.
Linn Sondek LP 12 with Lingo power supply and Naim Aro tonearm for sale.
Afromosia plinth with Trampolin base and Cirkus bearing. Very good condition. .
I don't think I would go this route-I don't think I am that committed to the sport! If I fall for vinyl, I would; just cough up whats needed to get somewhere good. It's in the range a new bike, or ski week, etc. So really a matter of prioritization- that's what time will tell.Not a fan of the Mk1 Lingo (not heard the others) but not a deal breaker as it can be swapped out if you want.
Aro is a very popular arm on the LP12, almost cult status. Like all unipivots it has a very organic, fluid sound but a little laid back compared to a conventional arm and not as tight at the top and bottom. Again, it can be swapped out as they are sought after and hold their value. You want the box with it. Fixed geometry so limited ideal cartridge choices.
Bearing type is less important than bearing condition. I'm of the opinion that the Cirkus and pre-Cirkus are different rather than one being better and both can sound fine in the right context.
Trampolin, waste of space but easy to remove and sell.
Afro plinth was the standard finish in the early days. Looks dated now but a lot of people like as it's the quintessential LP12 look.
Good thing about the LP12 is that you can change virtually everything to get a deck that sounds the way you want. Bad thing is that you might have to.
A sorted Planar 3 should be more than good enough.I don't think I would go this route-I don't think I am that committed to the sport! If I fall for vinyl, I would; just cough up whats needed to get somewhere good. It's in the range a new bike, or ski week, etc. So really a matter of prioritization- that's what time will tell.
