beammeup
I have had a bit of an epiphany I was comparing two DACs side by side an interesting Starting Point System DAC-3 (battery powered TDA 1543 based) and my current Arcam irDAC.
The connection was USB (using AudioQuest Forest USB cable) from an old netbook PC direct to the USB input of both DACs. I proceeded to play music and found that both DACs were somewhat uninvolving.
I could not work out why the sound was quite flat and lifeless. Later I decided to put an old TeraLink USB / SPDIF converter between the computer and the DAC, this opened out the sound considerably! Far beyond any differences you are likely to get between DACs. If I had done my comparison with the irDAC tethered to SPDIF and the SPS DAC-3 tethered directly to USB then my conclusion would have been that the irDAC was way better but now I know this is certainly not the case!
Trouble is, the TeraLink converter syncd fine with the Arcam but not so the SPS DAC-3, something I have yet to determine as to why because comparisons cant be made unless they are on a level platform; but in conclusion the interface is far more influential than the DAC. Good ol SPDIF.
If youve always tried to get a good sound directly from the USB out of a computer try a good SPDIF converter first its certainly worth it even if you dont believe it!
