Aaargh MS problem - Word going bonkers..
Discussion in 'off topic' started by Michael L, Apr 4, 2011.
  1. Michael L
    Michael L Banned
    I've just spent three hours ( ish ) composing a letter - I tried to save and its frozen - the wee Orange box is just flashing and the edges of the doc ( if that makes sense ) are going grey / bold, grey then bold...
    any tips ( £10 fine to the first bloke to say "buy a Mac".)
    TIA
    M
  2. sq225917
    sq225917 situation engineer
    Try and copy the .tmp file it has created in it's folder, and pray you had autoback turned on.
  3. Michael L
    Michael L Banned
    ^ I have no idea what those words mean... <blushes...
  4. Anex
    Anex Señor Member
    Word is generally quite good at recovering files after a crash. You could force it to close and restart Word, but it depends whether you're willing to take the risk...
  5. Michael L
    Michael L Banned
    Don't think I have much choice. The dialogue box is ticking / flashing away and I cant seem to do anything to save, though I can minimise etc.
    M
  6. Cheese
    Cheese Bitter lover
    If you force-close the program, chances are you can still find the file somwhere on the HD. when you type *wrd*.* in the filename search field. Rename the file into something.doc and all will be well.
  7. Michael L
    Michael L Banned
    thanks.. here goes......
  8. Interzone
    Interzone pfm Member
    Sorry if I've misunderstood but did you do three hours work without saving even once?
  9. Greg
    Greg 2t5b
    <baited breath>
  10. Joe Hutch
    Joe Hutch Can you hear Talvin Singh?
    ITYM <bated breath> unless you have a hook in your mouth.
  11. Michael L
    Michael L Banned
    kiss kiss.
    Thank you.
  12. Greg
    Greg 2t5b
    tru :-D
