Hi
I am in the process of trying to revitalise a 401.
When I lifted the platter from chassis the bearing spindle came out with it, this was easily released from the platter with a tap, but I noticed a groove at the bottom of the spindle that may have held a retaining clip?
Having looked at the bearing housing I can see that the spindle might have been fed in from the bottom before the end bearing was fitted, can anyone tell me if this is true? And would this have and adverse effect on the 401?
Also the bottom bearing gasket is trashed, does anyone have an idea what to use as a replacement.
