tuga
Legal Alien
Well, if the two input frequencies are given to different drivers, then you can avoid IMD being generated by either of them. So in that sense you are absolutely correct. 8-]
However when two frequencies are given to a single driver unit the IMD tends to come from two mechanisms. One is the movement nonlinearity (mechanical and magnetic). The other is doppler effect. Both are generally very level dependent and rise rapidly with output level. For a given output level both also rise rapidly with *decreasing* driver size, all else being equal.
So it comes down to a matter of the design of the drivers. Not just how many you have.
I don't understand how you are reaching your conclusion. How does the fact that "large drivers produce less IMD" invalidate the fact that "2-way produces less distortion than a single driver covering the same range"?
